| Low compression - bad valve?; 1993 metro 2dr/hatch 1.0 | |
| Tweet Topic Started: Feb 16 2011, 06:33 PM (6,013 Views) | |
| Johnny Mullet | Apr 19 2011, 07:51 PM Post #31 |
We have a couple female members who have done lots of work to their Geo Metro here on the forum. One has actually tore down an engine and tranny or two and we have another one doing a tranny swap with some help. If you have a friend or family member who has any mechanical experience, you can buy the parts and rebuild the whole engine in a weekend especially if a machine shop does the head for you. |
| bogs | Apr 20 2011, 02:17 AM Post #32 |
Oh and welcome back to your thread I agree with the above, I would pm edg and see if he has any advice as well.
| mcmancuso | Apr 20 2011, 11:40 AM Post #33 |
Ok I think some of your questions wer ecovered, but I'll go through the list and make sure ![]() "Quick question about your "overheating" comment. I have not overheated the car recently... however, it HAS over heated a time or two since I've owned it. Are we to be concerned about ANY overheating at all?" If its been overheated at all, it should be checked for straightness, if its not flat, the machine shop will plane it. "As for a machine shop, I'm guessing I just check my local yellow pages and start calling them to get prices on.... what do I ask? Just checking the head for cracks and "planing" it (what is that exactly?). ?" Yeah, calla round, shop prices vary widely, and its unfortunately true, but you should probably have a male friend call... Some shops still don't take women seriously when they call about car repair work and it can make a difference in the quoted price tell them you want to have the head checked for cracks and flatness(maybe the wrong term here but they will understand) and have them do the valve install if you don't want to take that on yourself."As for the valves, if they are that cheap... instead of just purchasing 2 or 3, wouldn't it make sense to go ahead and replace all 6? This would be an easy removal & replace while in the midsts of the project.... right?" check on ebay, there's some kits with all 6 valves ($43 free shipping): http://cgi.ebay.com/ebaymotors/Geo-Chevrolet-Pontiac-1-0L-G10-Intake-Exhaust-Valves-_W0QQcmdZViewItemQQfitsZMakeQ3aGeoQ7cModelQ3aMetroQQhashZitem3cb2a48740QQitemZ260695164736QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories but the intake valves are usually 100% fine and do not need to be replaced. "The auction for the rebuild kit says this in the description: "Optional: If you want the oversize(s), please leave us a note in the Add Instructions to Seller box that PayPal provided when you go to check out with PayPal." I'm not sure what this is referring to, but do I need to ask about "over size" for this project?" Typically these engines do not need oversize rings/bearings just a hone with a ball hone and you're good to go on the piston rings. "The felpro gasket is only $48.99 (part number 9651PT), is this the gasket you were talking about? There are others made by the same brand, high performance, etc. for about the same price, does it matter?" The felpro usually has the correct size oil holes, and seals well, many manufacturers make these gaskets with undersize oil holes and the felpro almost always has the right ones. "Is this the only gasket that I need to worry about that is included in the rebuild kit from eBay? All other gaskets are good?" Yes, the others are fine "Now, since the gasket is under the minimum purchase price to use the coupon, what other items do I need to have on my purchase list for this project that I might be able to get from Advance to utilize the great savings included in the link you provided?" Additionally I'd pick up plugs(NGK v-power are good) wires, distributor rotor/cap if you don't know when they were changed last, and you'll probably need an oil filter and coolant, all of which you can use the discount on. If you're going to be doing any of the assembly yourself, pick up some copper gasket spray too, good stuff, spray it on both sides of all gaskets for a better seal. And some RTV ultra black for things like the cam/crank seals and oil pan. Good luck! |
| 93metrochick | May 26 2011, 07:17 AM Post #34 |
Thank you for the replies everyone. I hit a financial snag and couldn't get started on my purchases as quickly as I had hoped. If something else doesn't happen within the next week or two (knock on wood) then I'm hoping to make my purchases and tackle this project myself or find someone experienced with geos to do it.... one way or another, it needs to get done. The old girls is still running rough, but gets me around like a champ. Some days it runs a little rougher than other days but it hasn't been over heating and my oil level has remained stable. mcmancuso and Johnny Mullet : I'd like to get started soon and if I end up doing this myself or with some help, would I be able to PM you guys with questions along the way? I don't want to be presumptuous and assume that you have time to deal with a novice as I will probably be asking simple questions that should already be known by someone taking on such a project. |
| MR Bill | May 26 2011, 09:50 AM Post #35 |
Welcome back Bill |
| 93metrochick | May 26 2011, 10:12 AM Post #36 |
*sigh* I'm starting to feel very insecure about tackling this project. I had to google "egine crank", "engine block", and "engine head" to know what the difference was & what the parts looked like. Question: How do I know if I need lifters? I saw mention of this somewhere in another post but now I can't find it. I seem to remember that this was something I might want to do if I'm tearing into the engine anyway. I know they make some sort of noise if they are bad, but I don't know how to identify that.... my engine makes a lot of noise right now, ticking being one of many. haha Would there be a visual indication that they are bad once things are taken apart? Any special tools that I should be aware of needing in advance? I have a collection of the standard stuff, sockets, wrenches, etc. Also, would I need to get an engine lift/hoist for this job? Edited by 93metrochick, May 26 2011, 10:13 AM.
| 93metrochick | May 26 2011, 10:14 AM Post #37 |
Thanks Bill! |
| bogs | May 26 2011, 10:29 AM Post #38 |
Any questions you do have I hope you post right here, as they may well be the answers someone else needs but was afraid to ask. As well as JM and mcman, there are a host of others who have experience to add detail to the answers
| 95-3banger | May 26 2011, 10:59 AM Post #39 |
I just finished a rebuild on mine a few weeks ago. I think you could take the whole car apart with a 10,12,14, and 17 mm wrenches. Well, maybe the matching sockets too! Oh, and a long handled breaker bar for removing the head bolts. They are pretty tight. I think besides that, the toughest part was pulling the little rubber coated washers (under the 4 nuts) out of the valve cover so it would come off. You'll have to find a torque wrench to tighten the head bolts, but they aren't too hard to find (or borrow). |
| Memphis metro | May 26 2011, 11:26 AM Post #40 |
I have a lot going on but I might could help you out if you dropped it off in Memphis for awhile. |
| 93metrochick | Feb 19 2012, 09:14 PM Post #41 |
Just an FYI for those considering the purchase of the rebuild kit from the seller on eBay suggested here.... the gaskets seems to be crappy cheap ones. I purchased this kit and had the work done on my geo in September. In October I was back to adding oil in my car ever week or so due to an oil leak and I also had coolant leaking from somewere. It wasn't until this month that I was able to afford getting it fixed tis month (again) and had to replace the valve cover gasket as well as one of the manifold gaskets (can't remember which one it was). |
| snowfish | Feb 19 2012, 09:38 PM Post #42 |
Interesting. That's the kit I used a year ago. Sorry to hear yours went south so soon.
3:35 AM Jul 11
