| brake line part question; brake line part question | |
| Tweet Topic Started: Feb 16 2011, 09:35 PM (1,441 Views) | |
| halla5 | Feb 16 2011, 09:35 PM Post #1 |
I am looking to gather the parts needed to replace all the brake lines and fittings. So what size is the hard lines for a 1993 Metro convertible? Also what is the size of the fittings for the hard lines? How many fittings do I need? Any help would be great. Thanks Tiger |
| Rooy | Feb 17 2011, 01:46 AM Post #2 |
The hard lines are 3/16". The tube nut fittings are M10x1. You're going to replace every line and fitting, including the ones coming out of the master cylinder? I count 20 total fittings in the system. For the brake the brake lines you might want to check out "Cunifer" copper-nickel alloy line from http://www.fedhillusa.com if you don't mind spending a little extra since they'll never rust out. Otherwise, there is PolyArmour brand poly-coated steel line that AutoZone (and probably others) carries. If you can't find the fittings locally, I found an online source here: http://www.ind-supply.biz/estore/BQ4511.html Looking at the BrakeQuip catalog (http://www.brakequip.com/tubenuts.html), they have a few fittings that are M10x1 thread, so I can't be 100% sure about that particular fitting working. |
| Deleted User | Feb 17 2011, 04:01 AM Post #3 |
Man, that's a lot of work! Got rust?
| halla5 | Feb 17 2011, 07:32 PM Post #4 |
Yes rusty lines. At the state inspection they almost failed me for the rusty lines. Thnks for the help. Tiger |
| allmountain40 | Feb 17 2011, 08:46 PM Post #5 |
I have a wrecked 93 four door hatch. The brake lines are good, but if your interested I can look tomorrow and verify. I don't know how expensive they would be to ship, but it might be worth checking out.
| Deleted User | Feb 18 2011, 12:07 PM Post #6 |
Hey, halla5! Didn't realize you were so close! Pick-N-Pull has 8 Geo Metros of various vintages for your parts acquisition pleasure. Swing by the Downtown Airport with your ride sometime! |
Got rust?
7:44 PM Jul 10
