95 Geo Metro won't start... I need help!
Topic Started: Mar 30 2011, 12:23 PM (4,133 Views)
mwellner4
ok I decided to take the pistons out to clean them or possibly replace them... definitely replacing the rings. How in the hell do i get the oil pan off.. it looks like only 3 sides have bolts and the 4th side is covered by something else.
There are a couple of studs with nuts on them instead of bolts.
mwellner4
yeah i got the nuts... but there is a plate i think connected to the transmission covering the one side. I think im gonna have to take that off.
mwellner4
ok i got the oil pan off and the oil pick up tube thing that looks like a shower head... is there an special precautions when taking the cylinders out?
Just be careful to not nick the rod journals on the crank. Use a cut off broom handle or something and push them out the top.
mwellner4
will chemdip get the carbon off the pistons?
96Geoman
Take pictures of the main caps, notice which way the caps are facing, notice which way the pistons are facing.
Also, I believe there's an oil hole on one side of the rod, make sure the oil hole goes back on the same side of the block
mwellner4
Ok so I'm about ready to put it all back together theres a hole with something on the engine black with some thing that might be a valve or a sensor that looks like it unscrews with a flat head screwdriver... do i need to do anything with that?
Read the first post in this thread, I think you are speaking of the oil check valve. Make sure it is there when you put it back together. Third picture, first post.
http://geometroforum.com/topic/1987137/1/
