Low Compression on ALL cylinders?
Topic Started: Apr 6 2011, 10:45 PM (1,823 Views)
Metroid
Metroid
So some of you have been listening to my rants about my low mpg. After 150 highway miles I am only seeing 30 mpg. So I went into autozone today, borrowed their compression tester and I was getting around 70 on all cylinders dry. I am wondering if that sounds too low? My engine runs great just not getting the best mpg. Could a head gasket leak effect all 3 cylinders? My motor has 139k on it. Is that enough to wear the rings on ALL cylinders? Perhaps I did the test wrong, but I did check it twice. I didn't do it web because auto zone was closing. Wondering if my Geo is ready to die or if there is something I can do!
Metroid
Metroid
I realized I didn't open the throttle when I did the test. :banghead That probably didn't give it an accurate reading. S*&t! I guess I will go back and do it again tomorrow B-)
I'd redo the compression test. You probably forgot to hold WOT (wide open throttle) while testing. 70psi is way low to run at all.
How to guide is here.
http://geometroforum.com/topic/2574993/4/#new
:cheers
Metroid
Metroid
The instructions on the autozone compression test box gave the option of screwing the hose in like a spark plug or just holding it in the cylinder. I thought that to be odd since pressure could escape that way. Oh well...I will try again...sigh...
Hey, don't be discouraged, this is how you learn. I can't tell you how many things I blew up before getting it right, but eventually you stop making mistakes and then you are an expert ;)
Mine was 130 with no throttle...and 190 with WOT.
Metroid
Metroid
Hey guys, thought I would update. After kicking myself for buying a $1000 dollar car that got near the same mileage as my Tacoma pickup, I found it out it was just the MAP sensor being disconnected :D . I have yet to burn a full tank since then but after driving 90 miles and parking on level ground, the fuel gauge still reads a little above 3/4 full, and this is just city driving. This is right on par with what is should be getting. I will probably re-fill her around the 350 mile mark. :cheers
Glad you found that.
Congrats on being back on track. Looking forward to your report on the new mileage.
