| Help 97 metro fuel injection problem; need help | |
| Tweet Topic Started: Apr 12 2011, 10:04 AM (2,182 Views) | |
| allynjones541 | Apr 12 2011, 10:04 AM Post #1 |
I have a 97 metro lsi with the big block 4 cylinder. i bought the car about 6 months ago for 125 bucks they said it wouldnt run. They had diff mechanics look at it couldnt figure it out i open hood n see an alarm removed that put in a new batt and bingo it runs great. "it sat for a year" now it tried to die a few times on me on the highway like it was starved for fuel floor it it would eventually pick back up. It died on my fiance and ive checked it out and no fuel out injector. Has good pressure out of pump as far as i know good spark to just injector not firing. WTF please help.
| Memphis metro | Apr 12 2011, 10:11 AM Post #2 |
Welcome to the forum. Check all fuses. |
| allynjones541 | Apr 12 2011, 10:20 AM Post #3 |
All the fuses are good. I wish i had a niode tester light to check pulse on injector. thanks for the welcome. |
| Bad Bent | Apr 12 2011, 05:46 PM Post #4 |
Welcome to your new forum, allynjones541! Click on 98 died at intersection. There is an injector test described that should identify the problem. |
| allynjones541 | Apr 12 2011, 08:19 PM Post #5 |
thanks ill try that |
| eric72blu | Apr 14 2011, 06:54 PM Post #6 |
| allynjones541 | Apr 15 2011, 03:56 PM Post #7 |
It does not have power to both injector pins. doesnt matter temp been sittin three days saw thing about inject resister does any one know the specs of ohms for that and where it is thank you |
| mwebb | Apr 15 2011, 09:44 PM Post #8 |
FOG
which pin does it have "power " to ? in this case "power" = 12 volts positive |
| allynjones541 | Apr 16 2011, 05:26 PM Post #9 |
if your looking at it from front it would be the one on the left any help would be greatly appriciated. thanks |
| mwebb | Apr 16 2011, 07:34 PM Post #10 |
FOG
it was a loaded question if either pin has 12 volts positive and the other does not , then the coil inside the injector is open and the injector is KA KA. the coil in the injector is the coil of an electromagnet when the ECM grounds the other pin the electromagnet energizes and pulls a steel iron pintle off of a seat allowing fuel to flow , |
9:39 AM Jul 11
