| High "hunting" idle; Idle problem | |
| Tweet Topic Started: Apr 14 2011, 10:08 PM (707 Views) | |
| vanguard | Apr 14 2011, 10:08 PM Post #1 |
Fresh Fish!
Good day, you experts! I have a nice 1.3 '96 Metro ( 130 k miles) that I really like. But it has a high (1800-2200 RPM) idle which "hunts" between those two rpms. Anyone have any ideas?? I sure would appreciate some feedback on this, it's confusing me no end! Thanks, "vanguard" |
| Memphis metro | Apr 14 2011, 10:21 PM Post #2 |
Vaccum hose off of something maybe. Is your check engine light on? Welcome to the forum. |
| bigsquat | Apr 14 2011, 11:36 PM Post #3 |
check the tps setting |
| CityConnection | Apr 15 2011, 01:01 AM Post #4 |
Sir, yes sir!
Was any work recently done on the car? When did this problem start? |
| vanguard | Apr 15 2011, 08:28 AM Post #5 |
Fresh Fish!
No, nothing obvious started the problem. This morning I will check the hoses and look for any blockage or whatever. Thanks for the question! NL |
| Bad Bent | Apr 15 2011, 07:26 PM Post #6 |
Welcome to your new forum, vanguard! Might consider just replacing the vacuum hoses. Shouldn't cost over $10 and you will know you have good hoses. One way to find a leak, which may be a gasket, is to spray the area with spray carb. cleaner and listen for a change in the engine tone. Even the PCV valve can be suspect if it sticks open.
| chubart | Apr 15 2011, 07:34 PM Post #7 |
I was thinking the same thing BB. What's to your knowledge has been replaced? A bad PCV could be the culprit. |
9:39 AM Jul 11
