| Cleaning Old Water Pump; How to make a used water pump gleam | |
| Tweet Topic Started: Apr 17 2011, 07:12 PM (1,155 Views) | |
| Metro Fanatic | Apr 17 2011, 07:12 PM Post #1 |
I recently bought Chubart's water pump. I'm going to clean it up and paint it to keep on a shelf as a spare. Any issues with leaving it to soak in my parts cleaner for a few days? Any points need special lubes? Thanks |
| Deleted User | Apr 17 2011, 07:35 PM Post #2 |
I'd just get it as clean as possible with dish soap and a brush in the sink, while the wife isn't looking, of course, unless she has a sense of humor about washing car parts in the sink. Make sure the old gasket is completely removed. A little piece of 80 emery cloth will slightly roughen the mating surface for gasket sealant adhesion in the future.You really don't want to soak it in anything. The bearings are resistant to coolant, but I'm not sure what else they're resistant to. Paint hides a multitude of sins. Give it a light shot of your favorite flavor of RustOleum on the outer surfaces once it dries. Put it in a large zip-lock bag for safe storage. While you're at it, get a new water pump gasket and put it in the bag, too.
| Deleted User | Apr 17 2011, 07:40 PM Post #3 |
Hammered Rustoleum Silver - Peppered with Hammered Rustoleum Black.
| Metro Fanatic | Apr 17 2011, 07:45 PM Post #4 |
Looks nice. Good idea on the zip lock. Should I put some sort of oil in there too? I'm thinking a mist of something as another corrosion inhibitor. |
| Deleted User | Apr 17 2011, 07:48 PM Post #5 |
Dry in the zip lock bag is all you need to do. |
| chubart | Apr 17 2011, 07:51 PM Post #6 |
I just might tear up when I see it all cleaned up
| Metro Fanatic | Apr 17 2011, 08:14 PM Post #7 |
Chubart...Don't be sad, be happy, it's going to a good home. You're not losing a water pump you're gaining a.....(can't think of a good ending). Thanks for the pump. Let me know via pm when that check gets there. |
| chubart | Apr 17 2011, 08:19 PM Post #8 |
Good to know I knew someone could make use of it
9:39 AM Jul 11
