end play
Topic Started: Apr 19 2011, 06:48 AM (926 Views)
bigsky
what is the acceptable amount of endplay in a 93 g10? i looked in the book and i couldnt find the spec. there is a noticable knock when i push the crank foreward. dial indicator says .003 is that acceptable or did i install the third bearing cap incorrectly? the thrust bearing and crank surface are in phenominal condition. thanks.
jellybean
end play .0044-.0122"
.11-.31mm from my 97 manual on a g10
Edited by jellybean, Apr 19 2011, 10:29 AM.
mcmancuso
mine moved .0675", 1/16"... thrust bearing was half gone :smackface PO liked having his foot on the clutch I guess...
bigsky
i am at three thousandths...so i poked the pistons in....gettin close...just waiting for my crank repair sleeves to show up....thanks guys.
91 ragtop
What are crank repair sleeves?
Ken.....
bigsky
the front and rear main seals on the crank wear grooves in the crank. these grooves leak oil if not attended to. so some ingenious feller took a piece of stainless steel and rolled it to .018 thick, and now he sells them. they are the diameter of the front and rear main seal area of the crank, you press them on and voila...groove addressed. seals ride on top of the sleeve...no need to replace the crank or have it ground and an oversized seal installed.
bigsky
Apr 19 2011, 07:49 PM
I've used this type of product before. The one I bought was called Speedi-sleeve. Works well and last about as long as the original surface, read and follow the instructions carefully for best results. Good Luck!
bigsky
yeah they are 8.00 a piece and supposedly last 150000 miles...i cant wait to check them out...the seal grooves was the only thing wrong with the innards of the crank case...
