| Camshaft seal; Replacement | |
| Tweet Topic Started: Apr 22 2011, 08:45 AM (821 Views) | |
| geodad | Apr 22 2011, 08:45 AM Post #1 |
DIY Mechanic
I am replacing the camshaft seal today. I've read about using some RTV to help get a good seal, but where exactly do you put it (inside of seal, shaft, etc.)?
| Memphis metro | Apr 22 2011, 08:47 AM Post #2 |
Put the rtv around the outer circumference of the seal. Welcome to the forum. |
| snowfish | Apr 22 2011, 08:48 AM Post #3 |
A little around the Outside on the pressing surface. Holds it better since it's a pretty loose fit. Only oil, or grease, on the double lip shaft seal surface.
9:36 AM Jul 11
