| Won't start; Sitting a while and won't start | |
| Tweet Topic Started: Apr 22 2011, 12:38 PM (461 Views) | |
| NormanMc | Apr 22 2011, 12:38 PM Post #1 |
It's my wife's 1997 metro LSI 2 door hatchback, 4 cylinder. It has been sitting around for about 2 years and always started right up. I told her to run it about every 3 months to keep the oil, and battery up. She hasn't started it since last fall and told me the battery was dead. I went to look at it and the battery is fine. It cranks and sounds like it wants to start but just won't. I was messing with it today and got it to start if I held the gas pedal down almost all the way, but it didn't sound good. There is a possibility that something got in and ate some of the wires but I haven't seen and chewed up. Sounds to me like lack of fuel, so I looked for the fuel pump but didn't see anything. I'm assuming it's on the gas tank? Any ideas or suggestions are happily accepted. I don't know very much about the Metro since I have never had to work on it. Thanks in advance. |
| mcmancuso | Apr 22 2011, 12:44 PM Post #2 |
its INSIDE the gas tank, not fun pour some marvel mystery oil into the cylinders through the spark plug holes, its good for un-gumming rings that have been sitting for a long time. And get rid of the gas in the tank, its probably the cause of the no-start condition, it'll partially fall out of solution as a varnish like substance when it sits for that long, and can clog lines/pumps/filters.
| Bad Bent | Apr 22 2011, 11:27 PM Post #3 |
Welcome to your new forum, NormanMc! True, these are fuel injected engines but when my van has sat all winter the first thing I do is pour a little fuel into the Carb or in our case the Throttle Body. Starter fluid might be good. BUT I use STA-BIL Fuel Stabilizer in my van, snow blower and lawn mower during the off season, before storage or long periods of non-use. Seems to work. Gas pedal to the floor opens the butterfly valve to allow more air in. It may have flooded. Besides mcmancuso's suggestion, I'd simply replace the plugs, unless they look clean, but I doubt it. The 2-3 tsp of Marvel Mystery Oil can be pumped out of the cylinders before starting with the plugs out, coil disconnected and rags covering the plug holes, if I recall correctly.
| NormanMc | Apr 23 2011, 04:09 PM Post #4 |
Thanks for the responses. I drain the gas tank today, put in some good gas and it started right up . The oold gas had a strange smell to it and was cloudy.
9:35 AM Jul 11
