95 Geo Metro Help!; Rebuilt, but coolant problem and high pitched squeak
Topic Started: Apr 27 2011, 05:42 PM (524 Views)
mwellner4
Hey I just got my 95 Geo metro finally rebuilt and I got the compression back and it definitely has more power BUT... I dont think the coolant is getting into the engine, there is a high pitch squeak, and I dont think I have the belts tensioned right as the timing belt slowly starts to slide off luckily it hasnt skipped a tooth or anything. But I need help as to what to do with these problems. Thanks for all the help on the rebuild guys I needed it!
Check to see if you tightened the bolt in the timing belt idler pulley.
