IDLE AIR CONTROL VALVE; Where is it and how to clean it
Topic Started: Apr 27 2011, 08:03 PM (2,043 Views)
ogoz23
Hi I have a 2000 geo metro 3 cyl my car iddles up and down , i want to clean the idle air control valve where is it and how to remove it any sujestions or pictures ?
mwebb
FOG
ogoz23
cleaning the IAC will NOT solve your problem
describe your problem better . use great detail , under exactly what conditions does the symptom occur at ?
Is your check engine light on?
ogoz23
OK the engine sounds like the rpm's are low and you see the engine shake then sometimes the rpm's are a bit higher and the engine seems smooth but with high Tom's when the engine idles rough when is shaking if I give it some gas and let go the rpm's would stay a bit high I can't really tell you at what rpm's I'm running because I don't have a Gage again I just bought the metro and I don't know if this is normal for this car sometimes
ogoz23
And no the engine light was on but it was the upstream o2 sensor I change it with out disconnecting the battery and I drove it and the engine light came off I checked the computer for codes with no engine light on and it showed the map sensor that I find weird because it got the map sensor with out the engine light beeing on then they told me that was because I changed the o2 sensor with out disconectic the battery so I erased the code and now it shows no more codes
Turn your switch on but do not start the car and see if your check engine light comes on for a couple of seconds. If not, you may need a bulb in the dash. Could be blown out.
ogoz23
the engine light is working
