metal shavings when I drained the clutch fluid
Topic Started: Apr 28 2011, 09:09 AM (1,759 Views)
peggysue038
There is a grinding/scraping sound when I let off the clutch. I was thinking it was the release bearing,
but now I am not sure. I drained the tranny fluid and there were metal shavings in it.
Let me explain: Two years ago my husband was driving "my little red car"
He said he was driving and all of a sudden heard a noise and then the car skidded to a stop.
We towed it home and it say for a couple of years. I started it up a couple of days ago and
it goes in to all gears and drives but it is that grinding noise when I let out of the clutch and it also
grinds in neutral.
So what do you all think?
Tofuball
Strange Mechanic
Sounds like a release bearing to me too!
A bit of brass (shiny glittery fluid) and a few small flakes of metal on the plug are normal the first time you change trans fluid unless you double clutch a lot.
peggysue038
Thanks, well at least I did good on troubleshooting.
mcmancuso
Commonly springs can fall out of the clutch disc and jam in the pressure plate, it could have been something like this causing the initial symptom.
If there was some small brass and grey matter in the trans fluid, then that is normal, but if the fluid looked "metallic" and had larger pieces in it, then the noise you hear is an idler shaft bearing inside the trans and a rebuild or replacement will be needed and might as well replace the clutch when the trans is out.
Lil red metro
After resolving the grinding issue and draining all the tranny fluid, you should use GM Pennzoil Synchromesh fluid. It will shift smoother and perform better in colder months. Good luck.
peggysue038
Thanks you guys! I believe what initially happened was what mcmancuso said about springs can fall out of the clutch disc and jam in the pressure plate. Now I am trying to figure out what springs?
bourmanr
its the spring on th clutch disc itself that he is referring to...need to replace the clutch if that is what happened..Bob
peggysue038
Thanks Bob,
Yea that is what I am gonna do. Not my favorite past time, but I am pretty mechanical.
Take a look at Manual Trans Removal /Clutch Guide; How to remove the transmission
