1991 Metro acting funky
Topic Started: Apr 28 2011, 07:02 PM (2,002 Views)
Mikemetro
Try loosening the exhaust flange bolts. Take it for a drive and see how it runs. If it runs better then prob your CAT. Also you might have just knocked off a wire/vacuum line last time you were under the hood causing your code 23
23 is the Intake Air Temperature sensor mounted on the back of the air cleaner.
13 is the Oxygen sensor
Might be a bad ground causing both codes.
wizard93
Just because the ECU is sending a code for the oxygen sensor, doesn't necessarily mean that the sensor it bad. I've seen instances where the computer throws a code for a sensor and the sensor is still good. A code can mean that the computer is getting a reading from a sensor that is outside normal parameters. That can be secondary to another problem.
My Subaru did that a while back. It was sending a code for something else and it ended up being the knock sensor. I replaced the sensor, and the other codes went away.
Check all your vacuum lines and wires and make sure everything is plugged in properly.
