| removing head oil galley plugs; proper removal proceedure | |
| Tweet Topic Started: Apr 30 2011, 09:12 AM (945 Views) | |
| sean bean | Apr 30 2011, 09:12 AM Post #1 |
I have a 1990 G10 geo metro head I would like to clean out. I have never taken out oil galley plugs and don't want to mess up the hex heads. Do they need to be heated up. Are they installed with locktite. I need to buy a 5mm hex driver for my breaker bar and was wondering if that will do the job or do I need a impact wrench.Am also trying to find how many pounds of torque to use to re-install the plug. Thanks for any help better safe than sorry Sean |
| Deleted User | Apr 30 2011, 09:35 AM Post #2 |
Sean, I use a propane torch to heat the area around the plug. An allen wrench/socket on a 8" 3/8 drive breaker bar or ratchet will be adequate. Tap the allen wrench socket into the plug with a small hammer. A slight tighnening motion of the plug will help to break it loose. I use Loctite PST (liquid teflon) on the threads for reinstllation. Torque? I'm sure there is one, but, I usually tighten the plugs until they stop turning. It's a tapered thread. |
| sean bean | Apr 30 2011, 09:56 AM Post #3 |
Thanks Geo Glenn for the fast reply. I will try what you suggest. I was thinking this was the way to go about it but was not sure enough to attempt it and take a chance on stripping the plug head out. Thanks again Sean |
9:35 AM Jul 11
