OBDII Computer in a NON OBDII Car
Topic Started: May 3 2011, 11:08 PM (1,944 Views)
mcmancuso
May 4 2011, 09:49 AM
It does have the RPM function in the program, but you have to enable it. I think you can only do this by re-flashing the chip in the most recent version. I believe it was left out because its keyed off the injector pulse, and the injector pulse stops in many circumstances: EOC, DFCO, etc...
Yep, they were planning it exactly as you say, but also as you say there are a lot of circumstances where the injector cuts off, making it (imho) worthless as a tach. You can view the actual code here:
-> http://code.google.com/p/opengauge/source/browse/trunk/mpguino/mpguino.cpp <-
As far as the Mpguino being a pain to hook up, if someone as electronically stupid as myself can do it, I would suspect anyone could do it. The biggest problem I noticed other people having was that they weren't getting clean enough contact signals.
I did this by fashioning my own form of t-pins from paper clips and inserting them into the harness connectors, instead of stripping out wires. It has been working fine in this fashion since JBD sent me the unit.
nerys
Grr
ahh screw it. its only $55 so I bit the bullet and got the pre assembled unit paid for :-)
