| need help! metro is bleeding!; quick sleeve? | |
| Tweet Topic Started: May 4 2011, 08:12 PM (529 Views) | |
| 96geooklahoma | May 4 2011, 08:12 PM Post #1 |
I am having problems with the metro. i took it to a back yard mechanic, and he said the oil is leaking from the quick sleeve?? (i think) he said they don't even make the part anymore. am I screwed??? |
| Coche Blanco | May 4 2011, 08:15 PM Post #2 |
The hell is a quick sleeve? |
| dayle1960 | May 4 2011, 08:33 PM Post #3 |
Something you put your arm into and cry on? A little more description of your problem would help us diagnose it a bit better.
| wizard93 | May 4 2011, 08:36 PM Post #4 |
I believe that's the part that the muffler bearing rides in. |
| JellyBeanDriver | May 4 2011, 09:36 PM Post #5 |
Must be the quick sleeve on the crank snout. used to cover the groove worn on a cranksnout from the crank seal. You're supposed to install them with loctite to prevent seepage. Where is is leaking from? Where the seal rides on the sleeve or between the sleeve and the crank? |
8:01 PM Jul 10
