Fuel Gauge
Topic Started: May 4 2011, 09:22 PM (518 Views)
ehinson
My fuel gauge crapped out the other day, haven't had a chance to check the engine grounds or back at the tank.
I goes below empty, then it may rise some then drop back down.
Just in-case it's the sending unit has anyone found and replacements other than a junk yard?
Junkyard is your best bet.
mcmancuso
I hear there's another set of grounds for the gauge cluster maybe? double check there... And definitely check the connections at the tank, I'd say its a sending unit problem, maybe loose/corroded connection.
