| Camshaft Pulley; Camshaft Pulley | |
| Tweet Topic Started: May 4 2011, 10:37 PM (1,001 Views) | |
| geofrump | May 4 2011, 10:37 PM Post #1 |
My 92 died (1.0L, carbed, AC, auto) and judging by the way it did, I think the camshaft pulley stripped off the shaft. I think this has a stamped steel pulley rather than a cast one. What's the best solution? Can this pulley to shaft connection be repaired? Is there an upgrade to a newer version (cast)? What is compatible ? As the car came to a stop the engine made many turns while the camshaft was doing something else. What's the likelyhood I have valve or piston damage ? Your help is appreciated! Edited by geofrump, May 4 2011, 10:44 PM.
| Good bye | May 4 2011, 10:59 PM Post #2 |
That is an unlikely scenario. It is far more likely your square tooth cam belt failed. Your car is most likely fuel injected with one throttle body injector. There is a very good tutorial on replacing your timing belt here: http://geometroforum.com/topic/2232748/. If you want to upgrade to a half round tooth timing belt you will need both top and bottom timing pulleys and a 5 bolt fan belt pulley from a late 93 through 95 1.0. |
| Coche Blanco | May 4 2011, 11:01 PM Post #3 |
This is a non interference motor. |
| geofrump | May 5 2011, 08:42 AM Post #4 |
It really is a naturally aspirated carburator. It was rebuilt 25k ago and the idiot at the machine shop did something to the pulley/shaft. The camshaft lost sync upon first start. I returned the engine to the shop and they 'fixed it'. I haven't seen this up close but I suspect there isn't a key but more like a 'bump and hole' between shaft and pulley Given all that what do you think ? is there a camshaft/pulley upgrade ? Which years in light of this ? |
| geofrump | May 5 2011, 08:52 AM Post #5 |
On second thought, you may be right about the FI. My old school head perceives FI as a manifold injection but you indicated a throttle body injection. The carb looks conventional and I haven't looked down in it to see the old 'squirt' of fuel which I think would peg it as naturally aspirated. |
| Good bye | May 5 2011, 10:32 AM Post #6 |
There is a pin sticking out of the end of the cam and a hole in the gear. If the cam is not screwed up just replace the gear and get the bolt tight. There is a through hole in the cam under the valve cover to hold the cam. Lots of cars used stamped steel gears with no problems. |
| mcmancuso | May 5 2011, 10:45 AM Post #7 |
broken belt is much more likely. If it was the pulley it may have ruined the locator pin on the end of the cam as well and you'll need a new cam any '89-'00 cam will do. '93-'95 metros use a round tooth belt with a cast pulley:![]() past '95 they switched to a wider belt, it would also work, which ever one you get, make sure you get the crank pulley too and the right timing belt, and a new tensioner pulley. These are indeed non-interference engines and there's no valve/piston damage from it running out-of-time. |
| starscream5000 | May 5 2011, 02:40 PM Post #8 |
Only one way to find out for sure..... And it's not a carb. Your year Metro has a Throttle Body Injector, as do the vast majority of Metros. |
| Woodie | May 6 2011, 06:06 AM Post #9 |
EVERY Metro ever made is fuel injected. |
| starscream5000 | May 6 2011, 08:09 AM Post #10 |
Oh, that's right, was it just the sprints that were carb'd? |
| mcmancuso | May 6 2011, 09:29 AM Post #11 |
correct
| Good bye | May 6 2011, 10:47 AM Post #12 |
The JDM replacement engines are coming in with carbs, so there are some floating around. |
| Woodie | May 7 2011, 06:01 AM Post #13 |
JDM engines don't come out of Metros, they come from J. |
8:00 PM Jul 10
