Sparky the no fit plug; threads stripped apparently
Topic Started: May 5 2011, 06:11 PM (1,242 Views)
starscream5000
Is this a common problem for the newer designed G13's? I heard of other cases where the spark plug is getting blown out of the cylinder bore from being loose...
Not something I've seen come up here before, so I would venture a guess it isn't common.
mcmancuso
I'd say that because its a pain to get the plugs out, bolted under the coils and such, they just aren't checked regularly... both my first 'vert and my '99 4cyl had VERY loose plugs(hand tight), and the 4cyl eventually blew one out. I checked the rest and they were all pretty loose as well :smackface never trust the PO!
