Putting a 1.3 4 cyl. into a 'Vert?; ...hmmm....
Topic Started: May 6 2011, 01:58 PM (901 Views)
TimmyD
A Metro Driver
:hmm
....probably would get around 35 mpg...
...just thinking that I could swap the 1.3 from the '99 commuter into the '91 Vert..
...and vise-versa...
...comments?
Possible, but gunna be surgery. :gamerz Not a direct swap. Will need to move some mounts around, wiring harnesses, linkage mods, etc.
IMO, the only reason that I personally would do the 4 into a 3 hole, is to mod the snot, out of the 4, and build a cool hot rod. :nfs
Just have to figure out how to keep the front end from hopping! (while doing a burn out. I've only done one with my 3/5. :evillol It's gotta be hard on the equipment! :smackface )
Or just be easier on the gas at take off. :-/
mcmancuso
This is a project I have been planning, I've already got a wiring harness out of a '00 4 cylinder :D
TimmyD
A Metro Driver
mcmancuso
May 6 2011, 02:45 PM
...well that settles it, I'll wait for McM to try it first...
...I know it would be a bunch of work. I've been kicking the idea around for a few days now.
Figured I would see what you 'more-learned' Metrologists thoughts were about the venture.
wizard93
Sounds like a fun project. I can't see why you can't do it. Make it a project on here with lots of pics. :D
Well, for fun, click on VTEC Motor Geo Swap
wizard93
Now that is just plain sick. :shake :nfs
I wonder what they did with the G10 if it had one?
Lots of work, as you can imagine, not to mention you're having to sleep in your new shed . . . wife having to walk to the store and everything . . . cutting her car up for parts! :'(
Bad Bend and Snowfish have the cheap and easy solution going with that race car camshaft they have in theirs. 3Tech or Delta can turn one out for you.
Although :hmm . . . nahhhh . . . but then again :popcorn . . . . nahhh! :ermm:
Mac will get his done someday . . . :thumb
