P0116 New Trouble code; P0116 - Engine Coolant Temperature Circuit Range/Performance Problem
Topic Started: May 7 2011, 06:54 AM (739 Views)
ogoz23
Well i staterted my car this morning temperature was araund 78 degrees ive notice right away that my rpm's where at 700 the car sounded like it was going to stall then i drove for about 25 minutes and when i got home i notice that my temperature gauge was all the way down and in the ultra gauge temp read 144 , shortly after that my ultraguge give me the p0116 code what do you guys think i should do? :rocker
so now i have two codes
p0116
p0400
geogonfa
Check your thermostat...probable stuck open...
zcrayfish
Chatroom Addict...
In addition to checking the themostat and temperature sensors, check to see if your EGR valve is partially stuck open.
Edited by zcrayfish, May 7 2011, 11:25 AM.
ogoz23
how can i check if is partialy stick open the egr?
zcrayfish
Chatroom Addict...
This thread should help you:
http://geometroforum.com/topic/678529/1/
Pull off part "A" seen in the first picture of the above thread... If you push on the diaphragm, the pintle should move easily, and you should be able to blow air through the manifold ports easily.
ogoz23
ok so basicly take out the egr valve and blow air and see if air moves ? i know it has and exhaust and intake port in the inside and the a port where the vacuum line hooks up to wich one do i blow ?
ogoz23
ok i took out the EGR and let me tell you thats super clean and the passages even cleaner that you see the metal i also was going to change the thermostad and i notice that the car had no thermostad and i also changed the temperature coolant sensor that goes next to the thermostad i hope thats the right sensor will see if it works
chubart
Dang I was going to suggest cleaning the egr. :shake
chubart
The codes are egr and engine coolant related. So yeah check the thermostat and connectors and grounds.
Edited by chubart, May 7 2011, 07:27 PM.
ogoz23
Well like i told you guys i guess the previus owner removed the thermostad now that the car has a thermostad ones in a while i notice that the cars temperature hits 225 -230 and then probably 45 seconds later the temperature goes down to 200 what can this be???
mjspiess
It means it's getting pretty hot & your radiator fan is kicking on to bring it back down to 200. I assume you put a 195* thermostat in which is recommended. If you have no grill block & you're reaching these temps your water pump may need to be replaced. If you have a grill block & new/good water pump, you may want to cut away the radiator side to keep it from reaching these high temps. I'd say your radiator is good though since the fan is able to bring the temps back down. The water pump is easy to change out & is cheap. You can "test" the water pump by pinching the upper radiator hose once the thermostat opens (195*) and see if you feel any pressure building up in the hose.
chubart
And if it is indeed the water pump I got plenty of know how to help out, of course so do alot of other members. :thumb
