| Where is the CaM shaft Position sensor? | |
| Tweet Topic Started: May 7 2011, 06:29 PM (804 Views) | |
| SoloCon | May 7 2011, 06:29 PM Post #1 |
I have a 93 Geo metro thats not getting any spark, I was reading the post from mwebb @ http://geometroforum.com/topic/2703156/1/ and it talks about the CaM shaft Position sensor, where is this located? Also, how does it connect to the ECU? |
| Deleted User | May 7 2011, 07:00 PM Post #2 |
The CPS is in the distributor. Check the Tech Section for Wiring Diagrams. |
| geogonfa | May 7 2011, 09:46 PM Post #3 |
just a quick check...open the distributor cap and check the pick-up coil...I have seen the distributor bushing wear out and, the stator hit the pick-up coil...if it did you would see a lot of copper wiring wrapped around the distributor... |
| mcmancuso | May 7 2011, 09:54 PM Post #4 |
on both the previous posts, its in the dist. and if the bearing goes bad the dist will eat the sensor.
8:00 PM Jul 10
