P0122 TP Sensor Circuit Voltage Low; Got the code while ajusting tps
Topic Started: May 8 2011, 03:14 PM (864 Views)
ogoz23
ok i was just trying to ajjust the tps i hooked up last two wires closest to the firewall i got my negative probe on one and the positive on the other when i did it the the iddle control started moving but i only got .236 all the way to the left and .258 volts all the way to the right then right away i got and engine code(
P0122 TP Sensor Circuit Voltage Low,, did i fry it did i do it wrong ahhhhhhhh
:coffee
ogoz23
my volt meter was set in battery load test at 6v and it was reading .236 volts now i set it in (10 megaohm input dcv)and it read volts dont know why well i set the tps to 1 volt and now my rpms are at 700 and when i turn on the ac they go down to 500 and the engine light still on for p0122
ogoz23
now the engine light went away but the tps is not really working like before the rpms go to 600 with AC
