| 1991 1.0 Metro piston rings | |
| Tweet Topic Started: May 8 2011, 04:02 PM (1,297 Views) | |
| cturner87 | May 8 2011, 04:02 PM Post #1 |
What brand piston rings should I use in my 1991 metro 1.0 liter? Also my rod bearing don't have any markings on them, does that mean they are standard size? |
| idmetro | May 8 2011, 07:47 PM Post #2 |
I used the Hastings rings from parts dinosaur http://www.store.partsdinosaur.com/page17.html 19k miles later they are still going strong. Not sure about your bearings - you could put them in place and check with plastigauge which is always a good idea anyway. That way you would know for certain. Good Luck! |
| cturner87 | May 8 2011, 08:04 PM Post #3 |
Hey thanks, I was leaning towards using them but was not sure how good they are. I just need to find a berry hone, I guess a 280-320 grit would do it but never used one tho. I will get the standard bearings and check them with the plastigauge. |
| Murf 59 | May 9 2011, 05:08 AM Post #4 |
Very few Metros have had the crank turned. Most are using just stock main and rod bearings. There have been a few Q's here about rings. One of our friends recently got a set of rings and they were the wrong thickness. I also had a problem getting the wrong width of rings last year too. So make sure they fit in the grooves. How many miles are on your engine. If its a lot. Replace the bearings just for cheap insurance. So you know exactly what you have. |
| cturner87 | May 9 2011, 12:07 PM Post #5 |
I will be sure to check the rings when they get here. I am going to changing the rod bearings too. The odometer reads 59827 but there is an oil change sticker saying next oil change at 265687! I just bought the car about a month ago and am slowly getting it ready. I have ss exh valves coming from 3tech this week. I need to replace the whole exhaut sysem too and the windshield. I found a set of 13 inch rims and tires at the local salvage yard off a 93 hyundai. I used the bulge nuts and they fit great. |
8:00 PM Jul 10
