| Broken timing belt; timing belt | |
| Tweet Topic Started: May 9 2011, 01:36 PM (735 Views) | |
| whtenv | May 9 2011, 01:36 PM Post #1 |
I have a 91 Geo Metro that broke the timing belt, I installed a new belt and idler pulley, Deciced to start the Geo up to see how the belt runs on the gears, I decided to do this because of the rust pattern on the top gear, within a few seconds the belt had moved off of the gears a good 1/8 to 3/16 of an inch, does any one know why the is |
| mcmancuso | May 9 2011, 01:52 PM Post #2 |
It will do this until you put the lower belt pulley back on the crank, this lower pulley holds the timing belt on. |
| whtenv | May 9 2011, 01:55 PM Post #3 |
Thanks for the info, Im new to the forum and was reading others about the same problem, Thanks again |
| Bad Bent | May 10 2011, 12:29 AM Post #4 |
Welcome to your new forum, whtenv! May I ask where in Idaho? |
| Murf 59 | May 10 2011, 06:45 AM Post #5 |
Welcome to the forum. Got any pics of your Metro? |
8:00 PM Jul 10
