| rear axle nut | |
| Tweet Topic Started: May 12 2011, 06:12 PM (4,514 Views) | |
| Deleted User | May 27 2011, 09:13 AM Post #16 |
I think my '90 FSM has a misprint. Thanks Woodie. 2 sources, same numbers.
| Wade | Oct 23 2011, 12:40 AM Post #17 |
As much as we all love "Haynes"... ...the Front Hub Nut (Staked Nut).....129 Ft-lbs; the Rear Drum Spindle Nut (Staked Nut).....129 Ft-lbs. The Castellated Nuts, 108.5 to 195.0 for the front, and 58 to 86 for the Drum Spindle. Torque 'em within spec., line up the castellation, and install the cotter pin. If ya' look at the way it all goes together, the torque shouldn't be exerting any pressure on the balls. 'Least not the bearings balls.
Edited by Wade, Oct 23 2011, 12:46 AM.
| nineoneandblue | Mar 18 2015, 07:39 PM Post #18 |
Wanted to confirm front and rear axle nut size on my 91 vert, I'm thinking 30mm front, 22mm rear? Can one of you guys confirm that or let me know what's correct. Thanks! |
| yiffzer | Mar 18 2015, 07:48 PM Post #19 |
Forgot His Manpurse
Addressing OP: 74 ft/lbs. Do not do more than that. Haynes provided inaccurate information. |
9:50 AM Jul 11
