spraying carbon cleaner in spark plug inlet
Topic Started: May 14 2011, 09:36 PM (4,065 Views)
rmcelwee
starscream5000
May 16 2011, 11:11 PM
Devil"s own alcohol injection is a common upgrade for GTPs. I was thinking more along the lines of taking a hose from the windshield washer plumbing and running it to the throttle body with distilled water in the resivoir only.
Was there ever any doubt that I didn't do this as well <G>. Actually, this thread got me thinking about building one again. Was thinking about cheap three way valves on the way home last night (so I can swap between cleaning my windows and cleaning my pistons). The most difficult problem I ran into was how to keep the water from sucking out when I was vacuum. The Miata water reservoir sits much higher than the one on the Metro so the problem might not appear now.
http://www.lightweightmiata.com/jrsc/water/
I used the nozzle from a spray bottle, some hose, and my washer pump:
starscream5000
Good idea with the spray nozzle, I may try it like that.
ogoz23
what vacuum port would be good for that ? i like the winshield washer plumming idea!
