| 5th gear popping out of gear | |
| Tweet Topic Started: May 15 2011, 11:16 AM (519 Views) | |
| lowridergold | May 15 2011, 11:16 AM Post #1 |
i have a 1996 Geo metro and i can hold it in 5th gear but it starts to shake and it tries to push it out of gear. i am curious if that would be a clutch adjustment or transmission problem every other gear is ok and hope someone can help me with this thank you |
| JAMES | May 15 2011, 11:29 AM Post #2 |
Had the same problem with my 89 ,two years ago,ended up being the shifting fork ,but believe it or not, it was not that hard to fix ,i fixed mine without removing the trans, if you look you will find my post , that shows how i fixed mine.
| Murf 59 | May 15 2011, 11:36 AM Post #3 |
May also be a tired mount. Holding the trans in the wrong postion to reach 5th gear. |
7:59 PM Jul 10
