| 1993 metro trouble; stalling when changig gears won't idle | |
| Tweet Topic Started: May 15 2011, 03:16 PM (416 Views) | |
| farrowg | May 15 2011, 03:16 PM Post #1 |
i have a 1993 geo metro 5 sp 1.0 liter engine that recently began to try to stall out when changing gears or when u r driving in the city and have the engine wound up in 2nd and 3rd gear its like it's not getting enough gas .changed fuel filter and had fuel pump pressure checked, checked ok. always idle to low. help please |
| Murf 59 | May 15 2011, 03:39 PM Post #2 |
Check for a big vac leak. |
| Bad Bent | May 15 2011, 05:18 PM Post #3 |
And I'd inspect the plugs to see what color they were. Vacuum leak could be the PCV valve also. You can adjust the idle screw if you want: http://geometroforum.com/topic/2625456/1/?x=40 granted it is set low for a reason - maybe the vacuum leak was reason for the low idle? |
7:59 PM Jul 10
