| head gasket bad only 10000 miles; smoke after re-starting engine after15mile trip | |
| Tweet Topic Started: May 16 2011, 10:31 PM (780 Views) | |
| cweed | May 16 2011, 10:31 PM Post #1 |
Any bad brand gasket that are bad for leaking? |
| allmountain40 | May 16 2011, 10:39 PM Post #2 |
did you use new head bolts? If you didnt, this will happen.
| cweed | May 16 2011, 10:48 PM Post #3 |
Yes new bolts machine shop instlled head. |
| starscream5000 | May 16 2011, 10:58 PM Post #4 |
Was the head and block decked for straightness? |
| Blakexvx | May 17 2011, 02:38 AM Post #5 |
im curious if there was something left that could be getting burned up in the chambers that could have fallen in during install. if a machine shop installed it and decked it etc.. then it shouldn't have a problem. did you drive it 15 miles and then started it again and it was smoking? or did you drive it 10k miles then this happened? if it was a cheap gasket it could have failed but I don't see how that could happen if it was installed properly |
| jeaarthur | May 17 2011, 08:32 AM Post #6 |
I had the same problem and the gasket I had go bad was from Rock auto. It was made in china and after inspecting the gasket you could see where there was a defect and it failed. Just my two cents. I bought a victor gasket to replace it with and you could see a dramatic difference in the quality. |
| cweed | May 17 2011, 09:29 AM Post #7 |
Fail was after 10k gasket was parts dino. Bot rock auto gasket have not installed Yet will get victor gasket Android compare . |
| cweed | May 17 2011, 09:30 AM Post #8 |
Thank all for posts. |
7:59 PM Jul 10
