friends 92 geo, running rich
Topic Started: May 18 2011, 06:55 AM (838 Views)
bourmanr
Have a friend at work that has a 92 or 93 geo 3/5 that is running rich, so rich that he cant drive it, had it at the garage and they told him the computer in it went south, my question is is that possible or is it something else, thought there was a sensor that would go bad and cause it to act like this also? Thanks for any and all help. Bob
FlaRealtor
I know from my experience there are a lot of small things that will make it run rich. First two I would check is the MAP sensor and the Hose to the coolant sensor on the throttle body. Two easier fixes.
Flarealtor
bourmanr
ok sounds good, thought i heard on here about that hose to coolant sensor causing this...ill give him the info..thanks a bunch Bob
