| Name That Part; Its on the intake Manifold | |
| Tweet Topic Started: Jul 1 2011, 11:14 AM (2,163 Views) | |
| climbinghalfdome | Jul 1 2011, 11:14 AM Post #1 |
MPG OCD
Study this wonderful photo. Look at the bottom red ground wire circle and pretend its a clock. What part is between 10 and 11 o clock? Its white plastic, black, grey, and screws into the Manifold. I'll give you a hint, I think its has something to do with coolant. What does it do? What is its part number? Where can I buy one?
| mcmancuso | Jul 1 2011, 02:09 PM Post #2 |
that's the BVSV or TVV depending on year its some sort of vacuum valve for the evap system see diagram:![]() it controls the purging of the evap canister. |
| climbinghalfdome | Jul 1 2011, 05:53 PM Post #3 |
MPG OCD
Mine is located on a 1993 metro 1.0L G10. I broke mine while taking apart and cleaning the EGR. I'm new at this under the hood stuff. The learning curve is steep. Now that I'm pointed in the right direction I can take it from here. Thanks for your help. Kevin in the Grand Canyon |
| climbinghalfdome | Jul 1 2011, 06:15 PM Post #4 |
MPG OCD
That was a lie. I can't find the part number, or a part anywhere. I'll keep looking, but if you know whats happening let me know. Oh the parts diagram under my hood says its a "EVAP TVV". Where can I get a replacement? |
| climbinghalfdome | Jul 1 2011, 09:42 PM Post #5 |
MPG OCD
OK I've struck out for finding the TVV (thermal vacuum valve) even though "BestValueAutoParts.com" sells them for $35, but they don't really sell them. Note the single exit port. ![]() Note Both ports on the BMSV (Bi-metalic Switch Valve) used on the 1993 Geo Prism. Here is my question; Can I substitute the BMSV for the TVV if I plug off one of the two? Kevin in the Grand Canyon |
| Way | Jul 5 2011, 02:29 AM Post #6 |
Probably best to post in the "Wanted" section. Unless you have a Chevy/Suzuki dealer to check with as this is probably a dealer only thing. |
| Jman | Aug 30 2014, 09:37 PM Post #7 |
I'm Wondering if you ever found the part you needed? The AC Delco 214-933? I'm looking for the same thing for the same reason! |
| don_dowdy | Aug 31 2014, 11:29 PM Post #8 |
Do you have California emissions? The '93 engine I have has a BMSV but it only has one port. |
| mjspiess | Sep 1 2014, 08:58 AM Post #9 |
I have one for $6 shipped. It came from a '95 & looks just like the one in the pic. Let me know if you want it. |
7:58 PM Jul 10
