Hello, I'm new here; 95 Geo 3 cyl gutless
Topic Started: Jul 18 2011, 07:14 PM (790 Views)
wildman
wildman
I'm troubleshooting why my my Geo it really gutless and finding low voltage output at throttle position sensor and Map sensor. Replacing the sensors has not made a difference. Has anyone had similar problems and found a solution?
Welcome aboard eba! I'd be surprised if you had both the Map sensor and tps go bad. The first thing to do with a "gutless" metro is to run a compression check. Have you done that? right behind that I would clean all the ground connections in the engine bay. Then I would search for Mwebbs posts on testing the TPS with T pins. Good Luck!
G-ride
Welcome.
pibe-2010
Young Gun
Jul 18 2011, 07:54 PM
:gp yeah running a compression check is your best bet, Welcome to the forum :) pics??? :thumb
Spud
Welcome here
MR Bill
Welcome
Welcome here :) I would also suggest starting with a compression test.
Welcome to your new forum, eba! :coffee
Join in the merriment! :banana
