| Crankshaft? G10 | |
| Topic Started: Aug 1 2011, 11:20 PM (409 Views) | |
| solerpower | Aug 1 2011, 11:20 PM Post #1 |
Took the crankshaft out to have cylindars honed on my 90 g10, just to make sure nothing got contaminated. When I took it out there are two 1/4 circle rings that fit into the block on I think number 3. There are two gaps on only one side, which way do the gaps face? Thanks |
| Big Rhino | Aug 1 2011, 11:36 PM Post #2 |
Grooves towards crankshaft away from block. |
| 91 ragtop | Aug 1 2011, 11:39 PM Post #3 |
The gaps fit facing each other towards the vertical thrust journal on that number three main . Ken...... |
| solerpower | Aug 2 2011, 04:15 PM Post #4 |
Thanks, for the quick replys, appreciate it! |
| solerpower | Jun 28 2012, 12:47 AM Post #5 |
Allright, I had to revisit this because I'm finally back at putting together the other metro g10. I realized both post are contradictory to one another. Do the two gaps face the crankshaft or do they face the block? If they face each other they are facing the block. Thanks. |
| Geo Glenn | Jun 28 2012, 01:02 AM Post #6 |
What's in your engine?
The numbers/letters stamped on the parts go towards the block. |
| Jittney | Jun 28 2012, 01:04 AM Post #7 |
If you are standing in front of the block....with the crankshaft out....and the thrust washers placed correctly in the block....the thrust washers grooves are clearly visible. The grooves face away from the block....and will face the crankshaft when it is put in place. |
| solerpower | Jun 28 2012, 09:07 AM Post #8 |
Thanks guys! I have a feeling on my other build that I put the grooves the other way. Last night when I was looking at it I figured the grooves had to face the crank surface to bring additional oil down onto, otherwise they wouldn't do anything. I wonder what it's doing to the other crank not having them the right way? |
| clarkdw | Jun 28 2012, 10:45 AM Post #9 |
I can guarantee you that it is destroying the crank. The thrust bearings have bearing material on one side and steel on the other. It has to absorb the thrust load of the clutch when you push the pedal down. I made the same mistake many years ago on a Mini. Wrecked the special forged race crank in a very short time.
Edited by clarkdw, Jun 28 2012, 10:46 AM.
| Geo Glenn | Jun 28 2012, 11:03 AM Post #10 |
It is possible to very easily change the thrust washers with the engine installed in the car. |
| solerpower | Jun 29 2012, 11:51 AM Post #11 |
When I pull the tranny, to replace the torque convertor plus, hydrulic pump seals I will switch it around then. Hell though I'll still just pull the engine and put it on the egine stand, I hate doing all that work looking up. Damn! On the bright side I have another crank and thrust bearing sitting around. Does the crank have to come all the way off, or can I just remove the single 3rd main bearing cap and slide it out? Edited by solerpower, Jun 29 2012, 11:53 AM.
| clarkdw | Jun 29 2012, 11:55 AM Post #12 |
Pull the pan, pull the bearing cap and spin the bearing out. Easy. |
| solerpower | Jun 29 2012, 12:02 PM Post #13 |
Thanks, that will make it alot easier, as long as the crank isn't already fubard. |
| Jittney | Jun 30 2012, 01:06 AM Post #14 |
Straightforward simple directions ![]() Love it
8:57 AM May 24
