Geo Metro Adventures...what to check
Topic Started: Aug 12 2011, 02:39 PM (1,100 Views)
thatguy383
amatuer XFi collector
I want to take my car on a few lengthy trips before summer winds down, but it is currently leaking oil through the crank seal(probably) and onto the timing belt...is this ok in small quantities or is it a recipe for disaster(I know it's a non interference engine, but side of the road timing belt changes suck). I've checked all the fluids, but what else should I have with me when i go in case i need to do some fixes on the road?
This car has been great thus far with a few successful trips down four-wheeler trails and other places normal cars won't fit, happy Geo adventures all... B-) :rocker :stoner
Edited by thatguy383, Aug 12 2011, 03:05 PM.
econoboxer
I am the one on the left.
small toolbox kitted for your metro. Everything metric. 1/2 socket with a8,10,12/13,14 size sockets. Small extension, and medium extension. Cresent wrench, Vise grips. electrical tape. A flashlight with good batteries.
A few quick connects(electrical connectors). Wire stripper, and crimper. Small amount of baking soda that will fit in a film cannister. A length of 10 gage wire about 3 feet long( you never know when you will need it)
A set of wrenches in the same afore mentioned socket sizes.
Two phillips screwdrivers, one stubby, the other about 8-10 inches. A flat tip relatively short, 4-6 inches, and heavy long one for prying. A handful of zip ties, a pocket knife, some wd-40.
An extra key that someone other than you carries, or a hide a key on your car.
A few quarts of oil for long road trips, a gallon on water- maybe for you, maybe for your car, so make sure its potable.
thats about what I take on roadtrips.
thatguy383
That's a great list, i have nearly all that, including the water for me or the car i always thought that was a good idea, but what is the baking soda for? I also just put a key under the car just in case. I'm most worried about the timing belt oil issue, everything else seems good to go...
Shinrin
The oil shouldn't cause any problems besides of course, losing oil. Just keep a close eye on the fluid levels and top it off as needed.
econoboxer
you never know when you have to clean those battery cables
thatguy383
I cut a peep-hole out of the timing belt cover and it looks ok, can anyone else think of anything I will need before I take off on a 2000 mile jaunt?
Also* -is the temp gauge accurate in these things? Should I put a thermostat in or leave it alone...?
Edited by thatguy383, Aug 15 2011, 12:50 PM.
thatguy383
Aug 12 2011, 03:04 PM
In case you break down in the hood and you need to cook up a quick batch of crack to impress the locals. You've already got water, a piece of wire, and a lighter, right? Just dart into a drugstore and buy a cigar, you can cook in the tube and your significant other can transform the cigar into a blunt so everyone can get baked while you're cooking up the rock.
