Vacuum leak and low compression; If you have a vacuum leak can it lead to low compression in one or more cylinders?
Topic Started: Sep 6 2011, 11:01 PM (3,584 Views)
vikasintl
I am trying to understand if there is any relation between vacuum leak and low compression?
lets say you have a vacuum leak somewhere ...and you don't know about that and you check the compression
can it show low compression like 80,120,140 on respective cylinders? or there should be other reason for this type of compression?
bad valves cause that
allmountain40
Bad compression can cause low vacuum, not vice versa. Low compression on one cylinder is typically caused by a bad exhaust valve on that cylinder in these engines. A vacuum "leak" will only cause high idle and backfiring. :thumb
Stiffchezze
Sir Metrologist
Nope. The things that can cause bad compression:
1) Bad valve/broken valve
2) Bad piston rings
3) Bad Head Gasket
4) Bad/Broken Piston
5) Broken Rod
6) Misaligned/Broken timing belt. Causes the valves not to close.
7) Cracked block
Your numbers indicate either 1,2,or 3.
Anyone else want to chime in? Am I missing anything? :hmm
starscream5000
I'd say a combination of 1 & 2.
vikasintl
starscream5000
Sep 7 2011, 08:14 AM
You are so right ...
