| if it ain't broke....; Won't Idle when warmed up | |
| Tweet Topic Started: Sep 11 2011, 03:21 PM (357 Views) | |
| Geeeo | Sep 11 2011, 03:21 PM Post #1 |
Geeeo
Well on my freshly rebuilt 97 Metro which I love dearly I took it out on the freeway and drove about 90 miles, man it did awesome I'm glad. But still never decided to Idle, so I began looking around and discovered one of my Air Intake Temp Sensor wires was bare at the connector, I began to investigate I gently pulled and bent it and yep! I broke the wire off, couldn't just leave it alone no not Randy. Ok so I go to my local pick and pull yard and as luck would have it the car I got all my parts from was gone! And the other one .....you guessed it the harness I needed was gone. Oh Joy! Ok so 30 miles to the other wrecking yard and only two 95s and wouldn't ya know it the sensor connectors are totally different, So I took it anyway and what's this? An Idle speed controller I took that too, yea they are $250.00 -$550.00 new So I have one now if I need one. Ok rebuilt my original connector soldered and heat shrinked all the connections now to solder it into the harness in the car and test, I'm afraid that I'm not receiving 12Volts from the ISCR (idle speed control relay) to the controller I'll check further and update.
7:25 PM Jul 10
