loss oil; loss oil
Topic Started: Sep 11 2011, 05:03 PM (701 Views)
turboshop
i have a 1992 Geo 1.0 auto my problem is i am losing oil quite fast, in 200 miles over a quart, the car dose not smoke i did a compression test 180 across the board , Ive check every where for engine leaks and the engine is as dry as a bone. any idea's would be greatly appreciated
Good bye
Are you running 3.8 quarts of 5w-30? Over filling can push oil into the air cleaner and you may no see the puff. High milers can have worn or stuck oil control rings and still have reasonable compression. If you actually have an XFI then you only have two rings to begin with one oil control and one compression. Compression rings seal towards the top to keep the compression in and oil can go right past when the piston goes down.
starscream5000
That much oil in that short of time could be front or rear main seal or cam seal. Is your passenger side frame horn oily?
Good bye
Oil leaks can cause catastrophic failures like this. At least the frame horns won't rust. :D
turboshop
No there is no oil visible any where. The engine is dry, under the car is dry also and yes i changed the pcv no oil in air cleaner, no blow by, the car runs great, water temp is normal, i changed oil and put in 3,8 quarts, theres no oil in the radiator , this thing has me baffled, the oil has to be going some where but where is the question lol
starscream5000
What do the spark plugs look like?
turboshop
Spark plugs are new, look to be burning normal, like i said this car runs great cept for the loss of oil, this all began after i changed oil and filter, ive been over this car from end to end looking for a leak, everything is as dry as a bone
it does not smoke either
Stiffchezze
Sir Metrologist
Are you sure you put enough oil in it when you changed it? Kinda sounds like you forgot to top it off. :smackface
How many times have you had to pour in a whole quart after 200 miles? If it was just the one time, probably just a fluke. Just keep an eye on it. ^o)
starscream5000
Someone must be draining it out when you're not around then...
metromizer
Reminds me of an old Movie, Pete and Tilly I think, Carol Burrnett and Walter Matheau I think... the dad and the kid were ADDING gasoline to the neighbor's car, an older guy who watched his FE and liked to brag about the unbelievable number he was getting. They added for fuel weeks, maybe months. Then, they started siphoning, taking fuel away... the guy went bananas.
Good bye
We used to do that to a VW owner in high school, we thought it was funny probably drove that teacher nuts. That would drive me crazy now I have to admit. My car is so much fun to drive that the 46 mpg that it is getting is ok.
