A bit of Modifying?; Modified the rocker shafts to allow more oil flow to the rockers
Topic Started: Sep 12 2011, 04:27 PM (559 Views)
Geeeo
Geeeo
I could not understand why the exhaust rocker shafts were not receiving oil. I inspected them and noticed a dark spot that covered the oil hole in the head, I asked on here adn no one heard of any oil delivery problems, but I had lifters that wouldn't pump up. so..... I took a round file and my Dremil and slightly beveled the oil hoses on my rocker shafts to allow more direct path for oil to the shafts and rockers.
Well I guess it worked my lifters are quiet and the car runs well so Did I improve it? Maybe maybe not but I sure didn't hurt it!
This is before I "modified" the shafts and I hope both pictures came through you can see the after one too.
wizard93
You just might be on to something there...;-)
Good bye
Back in the 80s we used to do the same thing to high mileage small block Chevy rockers so they would oil properly. Good fix. :thumb
metroschultz
You are not the first one with this issue.
I have read several other threads on the lack of oil to the rockers on the 4 cyl's.
I bought one that had the rocker shaft worn almost in half because of it.
Not knowing any better, I just went to the junkyard and got a whole "new" valve train.
One of our members figured out that the rockers wears over time and slide sideways, thus, covering the oil supply holes. He was able to create a shim to move the rockers back into position and get the oil back to the lifters also.
Not having a machine shop, I would use your fix.
