| 95 swift doesnt run(g13); will start floored but dies | |
| Tweet Topic Started: Sep 14 2011, 12:56 AM (502 Views) | |
| flatblackpiece | Sep 14 2011, 12:56 AM Post #1 |
new rotar new cap new wires new plugs new fuel filter, getting fuel to carb, dont know if injector is spraying, runs super bad barely idles when floored and dies after a few seconds. Any ideas people its parked on the side of the road waiting to get towed...tryed new fuel. |
| carmech97 | Sep 14 2011, 08:55 AM Post #2 |
Backyard Mechanic
Sounds like low fuel pressure. Throw a fuel pressure gauge on it, you should have around 45 PSI. If not, check your fuel lines to be sure that they are not plugged. If ok, you will need to drop the gas tank to replace the fuel pump inside. Let us know what you find. Good Luck!!
| flatblackpiece | Sep 14 2011, 01:58 PM Post #3 |
how much are fuel pumps? thanks alot dude i really apreciate it |
7:25 PM Jul 10
