How to reattach rear window defrost wire?
Topic Started: Sep 15 2011, 07:24 PM (5,513 Views)
The rear window defroster has two wires that run to the left side and the right side of the window. The wire attached to the left side of the window fell off. Now I don't have any defroster. How do I reattach it to the window?
GeoStalker
Maybe with some sort of metal conductive tape???
90metro
Sep 15 2011, 07:36 PM
I tried the trick that Bogs ALWAYS says works, duct tape. That approach DID NOT work.
Double sided metallic tape? Wonder if this product is available. :hmm
Shinrin
Cut some aluminum strips from a soda, solder it together?
Dealerships make a repair kit for this. Call around some parts stores and if you get the right guy, he might know.
bennie442
The repair is simple. Solder it back on. Lightly sand the mounting spot and the frit element to make sure that the solder will stick to the repair. When done, apply an epoxy type glue to add strength to the repair because the solder connection in and of itself will not be strong enough to withstand any type of stress.
OK. But I've tried the old reliable solder iron. I could not get the right angle that would let the solder puddle. It hard to make the solder hold when you are upside down.
Is the soldering iron the correct tool, or should I break out the acetalene torch?
Solder runs towards heat. Get inside. Close the hatch. hold the soldering iron above the work area. dont heat the iron first or it will get too hot. hold iron in place. hold solder in place. just as soon as solder starts running get the iron away.
If your soldering iron is too big then a good thing to work with is a burning iron from a hobby wood burning kit. They have a work area about 1/8 inch in diameter.
bennie442
Dayle1960, the torch is overkill! It may over heat the glass and crack it! I was able to do this with a solder iron. First apply solder to the glass where the terminal mounts. Then hold the terminal in place and heat the mount top to bottom, top to bottom, etc to build up heat. Start adding solder when the terminal gets hot enough while keeping the iron moving. Your torch method MAY work, but that much head scares me.
