runs rough
Topic Started: Sep 16 2011, 05:17 AM (591 Views)
brutus2501
Know that the car is running it runs pretty rough. someone told me thats normal for 3 cylinder motors. Is that true and can i get it to run smoother.
metromad
Have you done a recent compression test? If not, do one and report your readings. If you have already done one, report your readings. These engines can idle a bit rough, but if you getting into shaky rough, you probably have a valve out. Start with the compression test.
starscream5000
They will never idle smoothly unless you have your idle bumped up abnormally high. They have an odd number of cylinders and cannot be perfectly balanced like a straight six can be.
starscream5000
Sep 16 2011, 11:40 AM
This.
