| 96 longblock in a 95 g10; idles great , give it fuel and it pukes | |
| Tweet Topic Started: Sep 17 2011, 12:15 AM (4,110 Views) | |
| G-ride | Sep 17 2011, 12:15 AM Post #1 |
I have a 95 g10 and just installed a 76k 96 g10 long block , she has good compresion , 185 / 180 / 190 , installed all new full walker exhaust , cleaned carbon out of passeges , it idles good , but the second you start to give it fuel it coughs , sputters , when you give it more she back fires through the air cleaner , thought the timming was off , but all the marks seamed to line up , no check engine light , the 96 block has a sensor plug under the motor inbetween the oil pan and crank pulley and the 95 block didnt , any ideas , thanks. |
| allmountain40 | Sep 17 2011, 12:22 AM Post #2 |
96 is OBDII wich uses a crank position sensor for the timing. Your 95 is OBDI, so it does not utilize this so its a non issue. Your timing is off somewhere, wether its the belt or the distributer or your plug wires are mixed up. backfire through throttle body is caused by spark plug firing when the intake valve is open. How many timing marks are on your cam gear? I know some late model engines have two, and you may be lined up to the wrong mark. I could stop by after GFNW tomorrow and take a look.
| G-ride | Sep 17 2011, 12:29 AM Post #3 |
That would be great , thanks allmountain40 , the cam gear has two timing marks. |
| allmountain40 | Sep 17 2011, 12:56 AM Post #4 |
OK. See you tomorrow!
| G-ride | Sep 17 2011, 08:04 PM Post #5 |
Allmountain40 figured out the problem with the motor , i didnt change the distributer from the 96 obd11 to the 95 obd1 , there different , the 95 has one pickup , the 96 has two pickups , the car runs great , thanks agin allmountain40. |
7:24 PM Jul 10
