EFE heater
Topic Started: Sep 22 2011, 02:29 PM (1,355 Views)
AmericanTrash
Picked up one from a junkyard, how can i test if its good? Or can anyone tell by looking at it?
AmericanTrash
Search. "EFE heater" I believe there is a test procedure. What was wrong with the old one? Before you install the new heater make sure you clean the channels with chemtool b-12. Also you better source the upper and lower gaskets. If the old gaskets are still intact maybe, MAYBE you can reuse them.
Just hook up the red wire terminal of the heater to the ground side of a car battery and the black wire terminal to the positive and see if it gets warm.
Bigshane90
What happens when you don't use the fuel heater?
Bigshane90
Sep 22 2011, 04:12 PM
Increases the length of time your engine runs in open loop and increases your emissions. The heater just increases effiency. Oh and it sends a signal to Washington informing them your vehicle is polluting the air needlessly and they inform the man on you.
AmericanTrash
my check engine light is on. Thats why I got this in the first place. (P1250)
http://geometroforum.com/topic/3557477/
Try this link. It might help.
