oil; Whats the best
Topic Started: Nov 14 2011, 12:34 AM (571 Views)
wildhair
Im sure this has been covered before, but I was wondering if a good synthetic 0w-20w or 0w-30w was a good idea
for the cold winter months.
I started my car the other day and it knocked a little until it warmed up. Kinda freeked me out. :(
The engine has been rebuilt, and has about 1000 miles on it, using conventional 5w-30w, and the temprature was around 20 degrees farenhiet. I know it will reach -30 before winter is over and thought a lower viscosity oil would be better suited.
Just wanted to run it by others who see the same type of tempratures as I do here in Idaho.
wizard93
Wow, that's some cold temperatures. Synthetic oils are generally less affected by temperature extremes. I would think a synthetic 5w-30 should be fine. I'm sure others will chime in on this relentless pursuit of petro perfection...
:gp
If you can get the 0W30 that might be even better for a below 0F start up and a coolant or block heater would be a great idea IMHO. :-/
0W-30 is a great idea for winter. If there had been such a thing when our cars were made I'm sure they would have recommended it. I personally think that a synthetic 0W-20 would work, but this is definitely outside recommendations, you're on your own if something blows.
Tofuball
Strange Mechanic
We're always on our own if something blows!
Tofuball
Nov 14 2011, 07:14 AM
No kidding, your driving a car well outside of warranty, buy a second crappier version of your model and experiment to your hearts content :lol
It blows that you are on your own. :-/
That's why we have GMF! :thumb
thatguy383
amatuer XFi collector
5w-20 synthetic blend is the best value for the money. It is made out of great base oil stock and has an excellent shear rate. All the benefits of a free flowing synthetic, but at half (or less) of the cost.
Cobrajet25
I have been running Mobil 0w-20 for awhile now. No explosions yet.
Tofuball
Strange Mechanic
I guess a good test is after 60K or more pop the engine open and check the wear patterns on oiled surfaces :)
Tofuball
Nov 15 2011, 06:43 AM
In that situation I would prefer to test by turning the key and driving off,. ;)
wildhair
Thanks for all the posts
I tried mobile 1
0w-30w and the noise on cold starts below 20 deg has stopped,
The lifters seem to have stopped clattering also "bonus".
So far I'm impressed.
Seems the extra cost of a fully synthetic oil may pay off in thel ong run.
