| G10t Intake removal | |
| Tweet Topic Started: Nov 21 2011, 10:40 PM (934 Views) | |
| gamefoo21 | Nov 21 2011, 10:40 PM Post #1 |
2 Swifts n a Turbo Sprint
Alright... I REALLY DO NOT WANT to have to pull the head off to undo 3 nuts. So anyone with a Turbo have a method to removing those evil fasteners. I've debated loosening the front engine mount, and drooping the engine. Any hints, I'm hitting this devil beyotch tomorrow.
| crankcase | Nov 22 2011, 12:15 AM Post #2 |
On the regular intake, 2 of them are a beyotch too. For those, a stubby wrench is good (5" or 6" ?? Any way, the optimal size). A ratcheting type is nice once you have it broke loose. I bought the Harbor Freight ratcheting set and they have been quite good, except that I keep losing them. Good luck. Also lucky you with a Turbo Sprint !!! |
| mwebb | Nov 22 2011, 01:00 AM Post #3 |
FOG
never did an intake on a turbo swift or metro but i have done zillions of intake manifolds on many different systems including NA G10 s and the BPY type VW turbo direct injection engines which are a great deal of fun . i use a long 1/4" extension and a flexible 12mm socket to get many / most of the asian intake manifold bolts . sometimes you need a leprechaun to get in there and get the last nut , when you get there , look for the path way to feed in the long extension with the flexible / wobble socket. there is always a pathway , the manifold was not born on the cylinder head |
| gamefoo21 | Nov 22 2011, 11:20 AM Post #4 |
Thanks for the advice guys. I'll try the wobbler and the 12mm, and hope I can get on that most despicable of all, the lower center nut. |
| gamefoo21 | Nov 22 2011, 03:45 PM Post #5 |
Mother F.... I had to use wrenches and very very short swings to get two of the bottom nuts, the bottom left is hidden behind a water outlet barb so you can't get a 1/4" socket in there...
| 91 ragtop | Nov 22 2011, 08:35 PM Post #6 |
I'd like to tackle a t3 manifold as the regular throttle body one is easy once you figure it out. Does the t3 have a egr valve? If so take it off to give yourself more room to work. As far as the middle bottom bolt you coud try heating up a 12mm box end wrench with a torch and putting more bend in it so when it is on that nut it doesn't hit anything. Ken... |
| gamefoo21 | Nov 23 2011, 01:34 AM Post #7 |
Nope, no EGR valve. Just evil castings, and piss all for room to work due to the location. Fussy work, took forever getting nuts off, went quickly putting it back together. |
1:59 PM Jul 11
