rough idle, low compression
Topic Started: Nov 24 2011, 12:22 AM (3,010 Views)
I've not had any need for them but I udnerstand the xfi rings may be tougher/pricier to come by. One option you might consider is to convert it to the standard 3 ring pistons, I think the general thought is that the 2 ring pistons don't really contribute that much to the overall efficiency (I know - every little bit helps , but if they aren't available then where are you?).
