losing power; I hit a speed bump going a little too fast
Topic Started: Nov 27 2011, 01:53 AM (1,088 Views)
GoCanucksGo
Hey guys,
So I hit a speed bump tonight going 35 kmh, didn't really think too much of it except that I drove about 25 feet and realized that I was hardly getting any power. I was hitting the gas and could hear the engine working super hard but I wasn't going very fast and by the time I got back to the pizza joint I work at, I could smell something burning. My first reaction was that I loosened my belt (it was already in need of a tightening to begin with) but I popped the hood and something was smoking.
It was pitch black in the parking lot so I really couldn't tell where but it looked like it was coming off the transmission side of the engine. We had a few basic tools that allowed me to tighten up the belt and it did help me when I drove home but only once the car was already moving, it still took me some time to accelerate from a complete stop. I only live a few kilometers from work but by the time I made it home I could smell something burning again.
Once I pulled it into the garage to check it out I didn't really see any smoke and unfortunately my distributor has been leaking since day one (I've changed the O-ring twice and I put on a brand new gasket and it's still leaking) so it's hard to tell if I've loosened something else and is causing a leak in fluids.
My check engine light turns and off every once in awhile, pretty sure it's my muffler but when I was driving, my CEL started flashing like a SOB so maybe I loosened something in my exhaust? I really don't know where to start with this, do you guys have any ideas?
Shinrin
Crawl under the car and check it out. Are you losing any fluids? Did you knock a hole in your transmission?
GoCanucksGo
wow I'm an idiot. I just noticed that my spark plug wire was separated from the spark plug itself, no wonder I was losing power. Does that also explain the smoke though? the spark plug itself didn't look that bad to be honest, I have a spare one in the garage so I'm going to replace it anyways but the top just had a slight layer of corrosion on it that I'm sure some emery cloth could fix no problem.
I'm in the middle of an oil change at the moment so I haven't fired it up to see for sure if that was the problem, I'll check it tomorrow. In the meantime, and this is totally a noob question but, is there supposed to be a gasket of some sort on our drain plug? It looks like there's some remains of one on the plug but I'm not entirely sure, I can't remember where I put my RTV sealant so I'll probably have to pick some up tomorrow when Alder Auto opens but do I really need to put some on?
crankcase
Man, it almost sounds like you lost your clutch.
Is it an auto or standard?
What kind of burn smell, rubber, brakes, electrical?
Edited by crankcase, Nov 27 2011, 08:57 AM.
Supposed to be a copper washer on the drain plug.
GoCanucksGo
crankcase
Nov 27 2011, 05:27 AM
It's a standard and the smell was similar to burnt oil or rubber, which is why I thought it was my belt
crankcase
Don't know how definitave a test this would be, but see how hard it is to push it in gear.
Clasic symptom is you reve motor, but no power goes to wheels.
