Added aux jack to factory AM/FM radio on GEO/DELCO radio; Aux jack hack
Topic Started: Nov 27 2011, 03:33 AM (18,960 Views)
petersond
MAST3RFUL
Do you sell these? If so where and how much? I mean the whole radio with the aux jack installed.
Wendell
awesome
Wr85
May 25 2012, 05:26 PM
I was wondering if anyone has done this mod to a 2000 Chevrolet Metro stereo with a tape deck. I followed most of cookiemonster's instructions but did not locate the brown ribbon style wires. The inside of my stereo is different. I was able to add the aux jack to the faceplate of the stereo. I just need to know which wires to cut and what to connect them to.
The following pictures are of my stereo and the inside boards. If someone can help me please chime in.
Thanks.
Face with aux jack
Tape deck
Back of faceplate
Main Board
I know it is a year late, but if you are still interested in the aux port, then here is the info you wanted. The wires coming from the spot I circled in your photo are the ones you want to tap into. They will allow you to take over the channel your cassette player is on. You will still need to put in a dummy tape to make the whole thing work.
Cut the cord off of your old cassette adapter and use it as your blank tape. You can just leave it in the deck and switch to FM or tape (which is now mp3) with the front panel buttons. That way you can stay plugged into the jack, or just stop playing tapes, cut your wires away from the tape deck, solder an audio cable straight to the two wires heading to the board and have the male parts of your cable hanging out in your car for easy access.
Ground your negative wires on the board anyplace there is a mounting screw, or anyplace on the board that is connected to a mounting screw, or anywhere on the case of the head unit that is metal.
I was messing with one last night. Different model but same wire config and it works great. Now I want to figure out how to short cut the tape deck all together.
Edited by Wendell, Oct 29 2013, 01:28 AM.
CookieMonster
Everyone, its been a while since my last login here. Talked to a few of you over the past years, checking my inbox and responding to everyone regardless of the age of the message later on. Thanks for liking the write up! Sorry about the long time absentee status I have taken on!
-CM :beer
faygoninja
i have a factory radio from a 96 sedan. if anyone wants it to do this pm me
LT7A
CM, it looks like another year has gone by since you've posted. Never would have considered installing a factory radio in the currently vacant radio-hole in my dash until I read this. Nice work. Hoping there might be a similar option for us pre 95ers.
mt999999
Self-Declared "Genious"
LT7A
Jun 11 2015, 01:33 AM
On the first page of the post, he used a 1993-1997 Stock AM/FM Delco. Don't know what year you need, but it is the same radio that came with mine originally.
z34-5speed
Formerly "Tech Certified"
If I had the time I would go hoarding the stock radios and do this to them, then flip them to Metro owners as a cheaper alternative to a new deck.
Otey13
Geo Nerd
http://geometroforum.com/topic/5788083/1/#new
mt999999
OK, so I was up until past 4 AM last night working on my radio... I just didn't want to quit until it was done! :D Not to mention, I had to repair a wire coming from the dimmer switch that a previous owner decided to snip. I followed CookieMonster's guide (linked below), and got great results. I now have an 1/8" aux jack in the face of my stock, dimmable radio (between the tone and fade knobs). The hardest part was cutting out a portion of the circuit board to make the jack fit, as this entailed soldering several wire leads on to complete circuits that were cut off. Lots of soldering involved! It sure was a son of a gun, but well worth it! :cheers
I wasn't looking foreward to all of the time consuming work, but I really wanted that aux. port. With CookieMonster's apparent abscence, I don't know of anyone else on this forum that will mod these jacks into stock radios. I feel that it wouldn't be very hard to do some more of them, so I would seriously consider adding these jacks to people's stock radios if anyone was interested.
http://geometroforum.com/topic/4595715/2/#new
Create a free forum in seconds.
